How change the Element Type and Order in Hypermesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello ,
I want to change 2. Order Elemets to 1.Order Elements in Hyper Mesh, I did it and export this new Model.
when I open this model(1. Order Elements) in Hypermesh, the Elements are not shown.
I tried to change the Element Type from SOLID187 to SOLID72 but, even at this time the Elements are not displayed.and the Elemet Types are still SOLID187.
my perpose is that I have to Run the new model(with 1.Order Elements) in Ansys, but with this Problem, ansys don't Run.
could you please tell me how can I solve this Problem?
1 - 30 of 641
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    In HyperMesh go to '3D' page and there go to 'order change' panel. This panel lets you change the order of your elements.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.bc06a98380802cc69d43230ff7e2ba67.png
    Please try this
    Thankyou
    Altair Employee
    OP
    Thanks Sanjay,
    I did this , but the Problem is that, when I change the Order and export it, and want to open it again, these Elements don't shown.
    for solving this Problem I change the Element Type.(SOLID187 to SOLID72)and change the Order, and export the Model, but again when I open it, These Elements are still SOLID178 and dont shown.
    I think we have to find a specific way to change the Element Type, that saved in Model.with regular wayis not Possible.
    thanks for your helping
    Hello,
    Can you please share the .hm file i will have a look at this.
    Thankyou
    Altair Employee
    OP
    I show a Picture here to see what happened when I changes 2.order to 1.ordet, and export the model and open it again and see the model like this.!
    Altair Employee
    OP
    before changing the order the element type is TETRA10 , SOLID185 (Picture1),
    I change the <?xml version="1.0" encoding="UTF-8"?>Picture1.thumb.JPG.e7de384a90086a8691457d6277773f94.JPG2. Order to 1.Order and the Element Type is Tetra4, SOLID45 (Picture2)
    I export the model in .cdb file and open it again, the Model look like the above Picture, (Picture3) and the Element Type is still SOLID185.
    but how it is possible ?!!!! thanks for your helping.
    Hello,
    After changing the order type as stated in the below post
    Hello,
    Please try this
    Thankyou
    In Ansys Solver go to Utility Browser and then to 'ET Type'
    There create a new ET Type
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.a16e649ebe4bdd6de0d14c80c788a1bc.png
    Assign the ET Type with Element type you want to change it to.
    Then go in the model browser and select that ET Type in the 'Type' field for the respective component.
    Now Export your model.
    Thankyou
    Altair Employee
    OP
    thanks but where is Ansys Solver and Utility Browser ?!!
    Go to View Menu:
    Check Utility Menu Option
    It will then appear next to the Model Browser
    I noticed that you are using v 11.0, please upgrade to 2017 as it is the latest one available.
    Thankyou
    Altair Employee
    OP
    can you please tell me now where is ET Type in Model Browse?!
    ET type is in Utility Browser.
    After creating an ET Type you need to go in Model Browser and then update the particular Component with that particular ET Type.
    Altair Employee
    OP
    I create a new ET Type , but can't see the last screen shot that you sent me.Actually I dont know where I have to go to do the update for this Component!!
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.b7765c0b1bd9a48cbafbf3909d0ec674.png
    In the Model Browser.
    Select the Component
    Then In Properties>>Type
    Please refer the image.
    Altair Employee
    OP
    I click right on the Component and select Edit.
    This Component have no Properties !(Maybe !)
    I have to create new  Property?
    Can you please check if it coming under Component Section.
    if not right click the component and select Card Edit and then select the ET Type there.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.077adca028625810171b00c7a740bc0c.png
    Altair Employee
    OP
    yes the Property is there, but when I Right Click on the particular property and select Edit, dont bring that page to change the ET Type
    Dont right click on the property. You have to right click on the component and then select 'CARD EDIT'
    Altair Employee
    OP
    Thaks alot, its Done
    Altair Employee
    OP
    Hello,I change the 1.Ordet Element Type to SOLID45 but its not Running in ANSYS.
    the 2. Order Elemet Type was  SOLID187, to which element Type I have to Change in 1.Order?
    Tetra10 = SOLID 187
    Tetra4 =?
    thanks for your Helping.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Tetra10 = SOLID 187
    Tetra4 =?
    SOLID164?
    https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/ans_elem/Hlp_E_SOLID164.html
    or SOLID45?
    http://www.ansys.stuba.sk/html/elem_55/chapter4/ES4-45.htm
    Altair Employee
    OP
    thanks for your Answer,but its not working , and the Model changed like this, and its still SOLID187 !
    Hey, after changing your elements to 1st order (3D => order change ), you HAVE to :
    • Define a new 'Sensor' for 1st order type element. I take SOLID45 as example
    • Define a new 'Property' for SOLID45 type:
    • Update your 1st order component:
    Here're my tests models:
    HTH
    Altair Employee
    OP
    Thanks, but I did it From another way.
    the Problem is that, ANSYS cant run the Analys when the 1. Order are SOLID 45 or SOLID 164.
    the Second Order is Solid 187
    Dont know how can I fix this Problem.
    Read my post ... carefully!
    After defining 'Type' and 'Property', you have to update your 1st order component yet?
    Altair Employee
    OP
    yes I update the Element Type.I select here SOLID164
    Altair Employee
    OP
    The problem is that, ANSYS cant determeined  the SOLID 164, First Order.
    and when I changed to SOLID 45 , it start to run but after a while stops, because of Element Type !
    I think non of SOLID 164 and SOLID45 is Correct !
    No no, update 'Property' for your Meshing component !
    Altair Employee
    OP
    thanks for your answer, How can I exactly Update the Property?
    Altair Employee
    OP
    I want to create the new Sensor, but dont know how ! I cant see the screenshots that you sent to me, maybe I use the older Version.
    Altair Employee
    OP
    I did what you told me, but I still have this Error messege in ANSYS and it stop analysis after 10 min.
    You can update the property by simply right clicking on the property and Card Edit.
    You can create a new ET_Type by simply going to 'Tools>>EtTypes Table'. Sensor is nothing but the EtType Table.
    For this please export the deck. Then open the exported file in a text editor and check whether the Solids are of the correct order or not. If not then simply edit them in the Text editor Only.
    Thankyou
1 - 30 of 641
