Altair RISE
Nominate Yourself Now!
Motorcycle Motion View Model - for Load Calculation
User: "Sudhanshu Kashyap"
Altair Community Member
Updated by Sudhanshu Kashyap
Hi Everyone,
I am in the process of making a motorcycle model in motion view and wanted to get the forces on each components under several Loading cases.
I am interested in finding the forces under vertical bump condition on front and rear wheels.
But, I am facing some problems in generating the results. As, the system has been run but still no results were generated.
Can anyone help me in this. I am uploading <.mdl>file.
<?xml version="1.0" encoding="UTF-8"?>2.thumb.PNG.ab8a00461961d4673d21715f7ffb595c.PNG
1 - 6 of 61
    OP
    Hi Everyone,
    I have imported the frame as cad file , not .fem file.
    User: "Chris Coker_21312"
    New Altair Community Member
    Updated by Chris Coker_21312
    Your frame graphic h3d is a graphic, not a flexbody.  I would recommended initially running the model without a flexbody, to get things fully debugged.  Then, create the flexbody and add it to the model.
    So, in short, uncheck the FlexBody (CMS) feature until you get a proper flexbody created to use with the model.
    Regards,
    Chris
    Another quick observation on your model.
    The mass and inertia values of your model are all 'zero'.  You will not get a valid solution to the basic equation F=m*a if all your 'm' are zero.
    Kind regards,
    Chris
    User: "Praful"
    Altair Employee
    Updated by Praful
    Hi Sudhanshu - I see couple of problems with the current model.
    1) Mass/Inertia for all the bodies are zero. You need to fix it.
    2) Graphic h3d cannot be used as a flex body. You need to generate a flexbody h3d via Flexprep tool.
    regards
    praful
    OP
    regards
    praful
    Thanks Praful for your reply.
    How to convert flexbody h3d via flexprep tool ? As I don't have .fem file , All I have is the cad part file as a Input which I have imported as a Geometry in Motion View.
    The CAD needs to be meshed to create a .fem file.  Then you can use the Flexprep tool once you have created the .fem
