Meshing failed
Hi!
I'm trying to mesh a solid with TetraMesh and it states the following error: '2 edges failed nodal setup. Meshing failed'.
But I can't see anything wrong or red colored or anything that tells me where the mistake is. Even with visualisation options. The solid is created properly with bounding surfaces so I guess there are not free edges.
Could you help me?
1 - 5 of
51
@SergioV: You have 445 elements with aspect ratio > 20! So please make correction of your 2D mesh before filling 3D.
If you can't see anything wrong, how we can see something without your model?
