Error in crash analysis of baja rollcage
Ashwani Mittal_21124
Ashwani Mittal_21124 Altair Community Member
edited October 2020 in Community Q&A
Hello Everyone,
I am trying to perform crash analysis of baja rollcage using radioss but I am facing the following errors:
ERROR ID :   286
** ERROR IN INPUT CONSISTENCY
DESCRIPTION :
   2D SOLIDS (QUAD AND TRIA) ARE NOT COMPATIBLE WITH N2D3D=0
 .. UNITS SYSTEM
 .. FUNCTIONS & TABLES
 .. MATERIALS
 .. NODES
 .. PROPERTIES
ERROR ID :   178
** ERROR IN PART DEFINITION (PROPERTY)
DESCRIPTION :
   -- PART ID : 20
   -- PART TITLE : Lump_MASS
   PROPERTY ID=0  DOES NOT EXIST
ERROR ID :   179
** ERROR IN PART DEFINITION (MATERIAL)
DESCRIPTION :
   -- PART ID : 20
   MATERIAL ID=0 DOES NOT EXIST
 .. 2D SOLID ELEMENTS
 .. 3D TRIANGULAR SHELL ELEMENTS
 .. SUBSETS
 .. ELEMENT GROUPS
 .. PART GROUPS
 .. NODE GROUP
 .. INITIAL VELOCITIES
 .. DOMAIN DECOMPOSITION
 .. ELEMENT GROUPS
 .. RIGID WALLS
 .. RIGID BODIES
 .. ELEMENT BUFFER INITIALIZATION
ERROR ID :   228
** ERROR ZERO OR NEGATIVE 2D SOLID VOLUME
DESCRIPTION :
   ZERO OR NEGATIVE VOLUME FOR 2D ELEMENT ID=3
ERROR ID :   226
** ERROR IN SOLID PROPERTY
ERROR ID :   227
** ERROR IN QUAD ELEMENT
For reference, I am also attaching .hm file and .mvw file.
Any type of help would be greatly appreciated.
Thank You in advance.
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited October 2020
    Please, use the 'Model Checker' Utility to perform a model check before running your model.
    It will show you some of your errors.
    This topic covers OptiStruct, but it is the same approach.
    Some of your errors might be related to mixed 2d and 3d elements in the same component.
    Some of them are related to lack of property or material. Please review your model with the model checker.
    https://community.altair.com/community?id=community_question&sys_id=f076043a1b2bd0908017dc61ec4bcbed
  • Ashwani Mittal_21124
    edited October 2020
    Thank You Adriano A. Koga, I have tried model checker as you have stated previously but I am unable to solve the error 'components have more than one element type' shown in the attached image. Even I have tried remeshing my model with quads elements then also I am getting the same error again.
  • Pranav Hari
    Pranav Hari Altair Community Member
    edited July 2020
    Hi Ashwani Mittal
    1. Go to 2D > Elem types and select all your shell elements and update as below image
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.7384c784be22fa5181b5ba5186421324.png
    2. Assign card image none to lump mass
    After making these 2 changes the analysis is progressing from my end. You can try it
    edited July 2020
    Hi Ashwani Mittal
    <?xml version="1.0" encoding="UTF-8"?>image.png.c5da16ad03c4246af05959743f522102.png
    Hi @Pranav Hari ,
    I have tried out your suggestion and it has removed my some errors but still I am getting following some errors:
     ERROR ID :   286
    DESCRIPTION :
     .. UNITS SYSTEM
     .. MATERIALS
     .. NODES
     .. PROPERTIES
     .. SUBSETS
     .. ELEMENT GROUPS
     .. PART GROUPS
     .. NODE GROUP
     .. ELEMENT GROUPS
     .. RIGID WALLS
     .. RIGID BODIES
    ERROR ID :   228
    DESCRIPTION :
    ERROR ID :   226
    Can you please resolve these issues?
    Thank You
Welcome!
Welcome!
