How do I access the command line in CADFEKO to --use gpu
User: "Mathew Mitchell"
Altair Community Member
Updated by Mathew Mitchell
My computer has an accelerator in FEKO. I want to speed up FEKO solver using the accelerator. It says to use --use gpu in the CADFEKO command line. I don't know how to access the command line. How do I do this ?
1 - 2 of 21
    User: "Mel"
    Altair Employee
    Updated by Mel
    You don't need the command line. You can enable from the CADFEKO or POSTFEKO:
    Note that the GPU is mostly used for the FDTD (time domain) solver.
    User: "Mel"
    Altair Employee
    Updated by Mel
    To do this from the command line only, open a Feko terminal (click below on the right)
    and then run for example:
    runfeko mymodelname --feko-options --use-gpu
