How to measure the distance between two nodes in X,Y,Z direction based on specified local system?
User: "Zheng Guotao"
Altair Community Member
Updated by Zheng Guotao
Following value in X,Y,Z direction is based on global system
1 - 3 of 31
    User: "Marine_Racollet"
    Altair Employee
    Accepted Answer
    Updated by Marine_Racollet
    Hello Zheng,
    In the Measure tool you need to switch from Interactive to Dimensioning. Select what you want to measure and in the pop-up you will have the opportunity to select a new system.
    Regards,
    Marine Racollet
    OP
    But there is no dimensioning option in Hypermesh 2022.3
    User: "Jason_Craanen"
    Altair Employee
    Updated by Jason_Craanen
    You will need to update the already available 2023.
