could you please let me know what is the version of HyperView and Ansys are you using?
what is the type of analysis you have done using Ansys?
Do you see temperature under result type under HyperView?
We support temperature plot for thermal loads.
Please Note: If you are a commercial customer, you can contact your localsupportfor a script that will help you do the same @ http://www.altairhyp...ortProduct.aspx
Hi jakub.ziontek,
Please Note: If you are a commercial customer, you can contact your local support for a script that will help you do the same @ http://www.altairhyp...ortProduct.aspx
