HyperView-HyperGraph
Hi i have some question. I have some kind of tube (thermal analysis). I would like to create curve, on X axis i want to have 1 node so 1 position on tube (first node 0mm, next 1mm, another 2mm and till end of tube), and on Y axis i want to have temperature. I have transient analysis so i need to have few curves (one on each time-step). Is it possible to do?
Thank you in advance!
Jakub
Hi Jaku,
Have you tried with Build Plots in HyperVIew?
Please note: if you are a commercial customer, you can contact your local support @ http://www.altairhyp...ortProduct.aspx
Build plot allows you to construct curves.
HyperWorks Desktop Applications > HyperView > Annotating Model Results:
Build Plots Panel
Hai good evening,
i want to select a curve from curve section and want to click apply button which is located in 'move to ' section through tcl code..anybody help me please..??
after selecting a curve window this scale/offsets and axis arrangement panel gets enable..in that i want to do this operation.
it is very important for me :-)
