🎉Community Raffle - Win $25
Join and Win
Work on hypermesh while macro is running in background?
Hello,
Is it possible to work on hypermesh when we are running a Tcl/Tk script?
I would like to use 'after 10000' command to halt the execution of the script for some time and I would like to work on hypermesh meanwhile.
Thank you.
1 - 4 of 41
    llyle_20499User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi Harish,
    If i'm not wrong, after 10000 will merely delay execution of next line. So what operation do you want to do in hypermesh?
    QuyNguyenDaiUser: "QuyNguyenDai"
    Updated by QuyNguyenDai
    IMHO, Hypermesh session can't run on multi-thread proc. So you can't do different tasks in parallel.
    @ Altair's experts: correct me if I'm wrong?
    Hi Livil Lyle,  'after 10000' I gave as an example. Actually, I would like the execution of the program to be halted by 30 minutes.
    Basically, I'm trying to write a 'save as' reminder program, which saves the file every 30min in a specified format.
    tinhUser: "tinh"
    Updated by tinh
    Hi Harish
    To halt a runnning script, you can use tkwait
    Ex:
    proc ::p_RunningScript args {
        #a very long time script
        for {set i 0} {$i<1000000000} {incr i}
              Do something...
              if {!($i%1000)} update
              if {$::halt} {
                   tkwait variable ::halt
    #before running, indicate halt=0
    set ::halt 0
    ::p_RunningScript
    #to halt above script, set halt = 1
    set ::halt 1
    #then call your save as reminder
    p_SaveAsReminder
    #to continue the halt script:
    set ::halt 0
    ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
