Hi ,
what is the command to select nodes by path?
Hi,
Please try with *createlistbypathpanel
Hi, Please try with *createlistbypathpanel
this command create a node path panel .....but I select two corners node of a element manually means node between getting selected.
how to do in macro.
Hi
You can use one of these
*nodemarkbypath $nid1 $nid2 1
*nodelistbypath $nid1 $nid2 1
*nodelistbypath2
Hi You can use one of these *nodemarkbypath $nid1 $nid2 1 *nodelistbypath $nid1 $nid2 1 *nodelistbypath2
Thanks tinh ...
