HyperView-HyperGraph
Hi i have some question. I have some kind of tube (thermal analysis). I would like to create curve, on X axis i want to have 1 node so 1 position on tube (first node 0mm, next 1mm, another 2mm and till end of tube), and on Y axis i want to have temperature. I have transient analysis so i need to have few curves (one on each time-step). Is it possible to do?
Thank you in advance!
Jakub
Hi Jaku,
Have you tried with Build Plots in HyperVIew?
Please note: if you are a commercial customer, you can contact your local support @ http://www.altairhyp...ortProduct.aspx
Build plot allows you to construct curves.
HyperWorks Desktop Applications > HyperView > Annotating Model Results:
Build Plots Panel
it is quite working, but cant do curves automatically (need to pick all point one by one)
Jakub,
Create node set with nodes of interest and use the same when working with Building plots.
Hai good evening,
i want to select a curve from curve section and want to click apply button which is located in 'move to ' section through tcl code..anybody help me please..??
after selecting a curve window this scale/offsets and axis arrangement panel gets enable..in that i want to do this operation.
it is very important for me :-)
