🎉Community Raffle - Win $25
Join and Win
Component meshed with tetra and exa
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi. I had to mesh a component. I cut the solid in some parts and I meshed one of them with tetra elements (as you can see in the photo) because I wasn't able to mesh it using exa elements. I meshed the remaining parts with exa elements. Does it make any sense to mesh some parts with tetra and other ones with exa? Should I have meshed the whole component with tetra elements? Thank you.
<?xml version="1.0" encoding="UTF-8"?>post-37159-0-29571500-1434569481_thumb.p
1 - 8 of 81
    Altair Employee
    OP
    Hi Mirino,
    You may have to consider the stress distribution when using a combination of element types.
    Please see the image below with stress results and stress flow for 1)Hexa 2)tetra 3) combination of tetra and hexa
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-20169600-1434604265_thumb.jp
    Altair Employee
    OP
    Hi Prakash, thank you for answering me. I notice that the second image (tetra) is different enough from the first (exa). Therefore, if necessary, is it better to mesh with tetra elements only a small part than the whole component?
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    It is possible to use a Hexa tetra combination, we often use a HEX core, with pyramids surrounding it and then a tetra layer over the pyramids,for CFD
    The number of elements and nodes generated by a brick mesh are of the order of 1/2 to 1/50 in comparison to a tetra
    mesh. A brick mesh reduces the solution time and results in the ease of handling the model on a workstation (pre and
    post display).
    Analysis types like crash or nonlinear give preference to brick mesh due to the number of nodes and mesh flow lines.
    The time consumed in brick meshing is more and requires experience, hard work, and a lot of patience too.
    Over the years, the algorithm for tetra meshing has improved and accuracy wise there is not much difference in tetra
    10 and brick 8 elements.
    Linear tetra elements are not recommended for structural analysis. They are very stiff and inaccurate, so use parabolic tetra (the second order tetra)
    Of course, there maybe certain cases like contact analysis where Bricks (Hexa) are better and thermal where Tetra 4 even would be a good choice.
    Altair Employee
    OP
    Mirino,
    If you think you cant squeeze hexa elements at some part of the model. You may insert tetra elements.
    A better alternative would be using 2nd order tetras instead of hexa or mixed.
    Altair Employee
    OP
    We used the mixte mesh for
    We used the same technique for complicated geometry for Samcef's solver.
    You have to use pyramid elements to connect two parts (TET & HEX). This kind of pyramid element is not supported by every solver (MSC Nastran?).
    If the size of analysis is not your problem, go for TET10, yes TET10, not TET4.
    In some case, you have to reduce analysis size, so the mixte TET/HEX is only choice.
    Altair Employee
    OP
    Thank you very much. I'm going to mesh the whole component with 2nd order tetra elements then. Anyway, why Prakash is it better to use tetra elements (2nd order) for the whole component instead of tetra and exa combines together?
    Altair Employee
    OP
    You can't say it's 'better' to use TET10 mesh than TET10/HEX20 mixte mesh. It's simpler to do, yeah! The quality of analysis depend to several factors.
    But some case, you have no choice because of huge number of nodes/elements of TET10 mesh.
    Altair Employee
    OP
    Mirino,
    You can see from a simple cantilever with solid elements in one of my posts above.
    The stress flow for mixed element type is different and you can see some localization of stress.
    As Q.NGUYEN-DAI it is simple to mesh for a simple static analysis and carry ahead and the choice depends on problem definition.
