"File being opened for reading does not exist" while importing stl
Hi all, I''m trying to read several .stl files (not at once) but HM throws the above-mentioned error no matter if they're saved as binary or ASCII. The files are rather large, between 50-500MB, but the file size normally shouldn't be a problem. The files definitely exist at the specified locations, so I'm pretty clueless what to do with that.
1 - 6 of
61
Version 2019.1, the files are being created with nTopology version 2.4.5 and can be read by Fusion 360, Inventor, Ansys Spaceclaim, Meshmixer and various others, so the files shouldn't be corrupt. I tried deleting the temp, setting and appdata files already, but to no avail.
I can import this file no issue into my Hypermesh 2019.1
HM model:
Show me the FULL path of your files?
