q1:How to batch import points created in Hypermesh into Motionview? I know there was a tool called MD_Tools before, but it doesn't seem to work for me. I'm using the 2025 version
q2:How to output points from an MDL and then import them into another MDL file?
q3:Does the bearing in the mechanical tool expansion package not work in XML format solution?
q4:does the PY file solver have more constraints? I recently encountered a problem where I can solve in XML format and then use Py files to solve. However, for the same file, PY will report an error and display a conflict in the ID of a certain ENTITY
q5:How to output a subsystem in Motionview and then import the generated subsystem into another MDL file?
