Splitting Solids with lines
I going through an optimization and I want to split bodies to design and non design spaces.
When I use the 'trim with lines' tool and select sweep all, the part is trimmed with the contact surface in yellow, however when I specify a length for the sweep,that does not go through all the body, the part is trimmed with the contact surface colored in red.
I have seen in a tutorial that yellow is a shared contact surface, which is what I need, so I guess red means the trimmed body will be free which will make it unusable.
I was wondering how can I solve this issue ??
I attached 2 screenshots where the first the sweep goes through all the body, the second one it goes only third of the way.
1 - 1 of
11
When you see red area from trimming operation, it's not so good! You will have some issue with meshing on it.
Try another method to split the solid.
