I going through an optimization and I want to split bodies to design and non design spaces.
When I use the 'trim with lines' tool and select sweep all, the part is trimmed with the contact surface in yellow, however when I specify a length for the sweep,that does not go through all the body, the part is trimmed with the contact surface colored in red.
I have seen in a tutorial that yellow is a shared contact surface, which is what I need, so I guess red means the trimmed body will be free which will make it unusable.
I was wondering how can I solve this issue ??
I attached 2 screenshots where the first the sweep goes through all the body, the second one it goes only third of the way.
<?xml version="1.0" encoding="UTF-8"?>.thumb.png.4db9806f3f9a576d0b42321d411e1929.png)
<?xml version="1.0" encoding="UTF-8"?>.thumb.png.e60670c936c086cbd048892792d737f8.png)
