Turn On Feature lines on using TCL\TK
Dear All,
How to turn on feature lines in Hyperview using tcl\tk.
I know the short cut key which is 'L' by pressing 'L' after loading mode (OP2 file) this will be done manually.
Please let me know the commands to set feature lines on in 'Display Control -> Boundary Geometry -> Features ' as below image. I need TCL\Tk Command please help.
Thanks
Vikas Kumar
Hi Vpin,
I am doing this but still it's not activating feature lines. Please help me.
My code is:-
hwi OpenStack
set t [::post::GetT]
hwi GetSessionHandle sess$t
sess$t GetProjectHandle proj$t
proj$t AddPage
proj$t RemovePage 1
proj$t SetActivePage [proj$t GetNumberOfPages]
if { [catch {page$t ReleaseHandle} ts] } { }
proj$t GetPageHandle page$t [proj$t GetActivePage]
page$t SetActiveWindow 1
page$t GetWindowHandle win$t [page$t GetActiveWindow]
win$t GetViewControlHandle view_ctrl_hdl$t
view_ctrl_hdl$t SetOrientation 'top'
view_ctrl_hdl$t SetPerspectiveMode true
win$t SetClientType 'Animation'
win$t GetClientHandle post1$t
#Load model
set model_id [post1$t AddModel $op2_file_path]
post1$t GetModelHandle mod$t $model_id
mod$t SetMeshMode 'features'
post1$t GetRenderOptionsHandle renopt_hdl
renopt_hdl SetUndeformedMeshMode none
renopt_hdl SetBoundaryMeshMode 'features'
page$t Draw
post1$t Draw
Thanks,
Vikas Kumar
Hello Vipin'
I think this command is for different purpose
SetBoundaryMeshMode – Sets the boundary mesh mode for iso and section cuts.
SYNTAX
poIRenderOptions_handle SetBoundaryMeshMode mode
TYPE
HyperView Tcl Modify
DESCRIPTION
This command sets the boundary mesh mode for iso and section cuts.
Note | This functionality is common for iso and section cuts. |
mode
Set to features or none.
ERRORS
Returns 0 if successful, otherwise an error code.
this is for this two..
Hi Vikas
Try the below code, but it only works if any section cuts are present in the model. I am not sure why it is not working on normal views.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options SetBoundaryMeshMode features
page_handle Draw
This will work only for ISO and Section cuts but my requirement is different.
Hi Vikas
hwi OpenStack
page_handle Draw
