Thermal analysis of forced convection
Hey guys,
I am investigating the thermal simulation capabilities of Hyperworks. For the current project we want to simulate a case which can be seen as a forced convection scenario.
It is all aboult a cooling system which exists from a aluminium profile and several fluids. We want to calculate the heat flux distribution (our goal: maximum heat flux), temperature fields, structural questions.
What I can not find is how to model a forced convection boundary condition. Let's say I know the temperature of my fluids as well as the heat transfer coefficients between aluminium and the fluids. How can I model this in Hyperworks? In Abaqus there is the possibility to model a so called film condition which allows me to specify heat transfer coefficients and temperatures of the fluids.
Thanks in advance.
Merula
Hi,
Please refer to OS-1090: Linear Transient Heat Transfer Analysis of an Extended Surface Heat Transfer Fin.
I hope this helps you to start with.
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
