Altair RISE
Nominate Yourself Now!
RENAMING COMP COLLECTORS IN HYPERMESH using TCL scripts
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi All,
Anyone can tell me the How to Rename the comp collectors in HyperMesh using TCL scripts.
For suppose Comp name : ABC12345_2.00T  and  PID : 1  OUTPUT : ABC12345_1
i want to keep that first eight digits, and i want to delete that thickness information and i want to rename with its PID
please tell me If anyone know
Regards,
Sudhakar
1 - 12 of 121
    Altair Employee
    OP
    Here is my not-yet-tested code:
    proc make_new_name { name } {
    # do some thing over current name to create new one
    return $newname;
    *createmarkpanel components 1 'Select compo'
    set listComp [ hm_getmark components 1 0 ]
    foreach compID $listComp {
    set name [hm_entityinfo name components $compID]
    set newName [make_new_name $name]
    eval *renamecollector components $name $newName;
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    below is a sample of 'make_new_name':
    proc make_new_name {name} {
    set i 1
    set _new_name [string range $name 0 [string last '_' $name]]
    set new_name ${_new_name}$i
    while {[hm_entityinfo exist comps $new_name]} {set new_name ${_new_name}[incr i]}
    set new_name
    Altair Employee
    OP
    hi  Q.NGUYEN-DAI,
    Thanks for your support.
    but i didn't get exactly '# do some thing over current name to create new one'
    what it means.
    Regards,
    Sudhakar
    Altair Employee
    OP
    Hi Tinh,
    Thanks  for your support,
    But Above what you mentioned TCL code not running.
    Regards,
    Sudhakar
    Altair Employee
    OP
    hi  Q.NGUYEN-DAI,
    what it means.
    Regards,
    Sudhakar
    Do you have some programming skill with TCL ?
    Altair Employee
    OP
    I have very basic Knowledge.
    Altair Employee
    OP
    Hi Tinh,
    Thanks  for your valuable support,
    using your TCL code i prepared tcl script to rename all the collectors.
    Thanks,
    Sudhakar Donepudi
    Altair Employee
    OP
    hi Sudhakar,
    What changes you made to the script provided by Tinh?
    If possible can you paste the complete TCL script you used
    User: "tinh"
    Updated by tinh
    hi Sudhakar,
    Hi,
    you can use this function
    proc make_new_name {name} {set i 0set name_ [string range $name 0 [string last '_' $name]]while {[hm_entityinfo exist comps '${name_}[incr i]' -byname]} {}return ${name_}$i}
    Altair Employee
    OP
    no i need to learn
    Altair Employee
    OP
    How to rename the components by thicknesswise by using script? please help me out.
    User: "tinh"
    Updated by tinh
    Hi,
    try this
    foreach compname [hm_entitylist comps name] {
         *renamecollector comps $compname $compname_[hm_getthickness [hm_getentityvalue comps $compname id 0 -byname]]
    and above 'proc make_new_name' is unneccessary, use hm_getincrementalname instead.
