How check if cweld is link only with shell?
Altair Community Member
Updated by Geraldo Osorio
Hi
Is it possible check if cweld(PWELD) ELEMID is linked only 2D(shell) rather than 3D elem( hexa/tetra)?
1 - 3 of
31
OPUpdated by Geraldo Osorio
Hi.
I tried your procedure but No elements were found. I think that CWELD isn't linked directly by nodes/elements.
Updated by Simon Križnik
Looks like the CWELD element is not attached directly to adjacent elements but through the tie contact.
In Radioss user profile there is the option to include tied contact. Unfortunately, such functionality is not supported in Optistruct user profile.
Hi,
try this procedure:
-isolate CWELD elements of interest with the mask panel (F5)
-in the Find panel (shift+ F5) find elements attached to the CWELD elements. The attached elements will be unmasked.
-check if the unmasked elements contain 3d elements (use the mask browser to show/hide entities by element types).
