Convert LS-Dyna adhesives to Radioss
Hello comunity,
I am trying to convert a LS-dyna hexa contact adhesive into a Radioss adhesive via hypercrash. I did it sucessfully with the spotwelds, using the tool 'Connections -> SpotWeld-> Extract from Model', but this same tool does not work when I am dealing with adhesives. Somebody has a suggestion?
Thanks a lot!
1 - 1 of
11
Hi
I suggest you to attempt with the latest HyperMesh.
If not converted , you can manually set the property using ,e.g. , /PROP/TYPE43(CONNECT) .
Regards
