to define a Non-Design Space for optimization, you need to create a separate component and property. It is necessary to either separate the areas on a geometry level (i.e. before meshing) or on the element level (after meshing). To do this on the geometry, you need to create different geometry areas. The geometry solids or surfaces need to be connected in order to get a coincident mesh on the shared surfaces and lines. This is done using Boolean Operations on 3D geometries and Geometry Cleanup on 2D geometries.
After meshing, you still can move areas to the Non-Design component. Please use the 'organize' function within HyperMesh.
The following movie shows all necessary steps on a simple part:
You have to mesh the midsurface, organize the elements into different components and assign different properties, refer the property of those elements you want designed while defining the design variable.
Hello,
http://screencast.com/t/AO8bdmh9E7
Jan
