Acusolve not configured
User: "MishaAtirah03_"
Altair Community Member
Description: Acusolve environment not configured
Product/Topic Name : I am using Altair Simlab, and when i am trying to run simulation.. It appears saying Acusolve environment not configured.
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
1 - 3 of 31
    User: "loistf"
    hi! I believe you can configure the path to the solvers via a certain *bat file in the installation folder. I don't have access to a simlab installation right now and i don't remember the exact name of the file, but if you search for a file with that extension(bat) that contains the string "acusolve", your should be able to find it and configure it. (i use freecommander or notepad++ for these kind of searches in windows)
    I hope it helps.
    User: "ydigit"
    Altair Employee
    If still relevant, the easiest way is to reinstall SimLab, however inculde the Additional package to have a complete installation, with all Altair solvers configured to run.
    User: "ydigit"
    Altair Employee
    See screenshot for the additionals ZIP.
