Altair RISE
Nominate Yourself Now!
How to use Type of prediction planes in WinProp API indoor
User: "Coco"
Altair Community Member
Updated by Coco
Dear,
I want to predict a plane I defined in database. I searched the pdf of the API and had these values.
However, I failed to find the corresponding variable for it. (xxxxxx = 0?) Meanwhile, I think in the indoor examples, in WinProp_prediction function, the area stored in WinPropArea is used, should it be replaced by WinProp_ResultPlaneList or what?
Would appreciate it if there's an example? or like names of examples in the pdf…
Thank you in advance,
Coco
1 - 1 of 11
    User: "Zeina"
    Altair Employee
    Hi @Coco ,
    You will need to :
    1- Change the Structure WinProp_Area to WinProp_AreaPlane
    2- Pass it on to the WinProp_Predict_Planes function instead of WinProp_Predict
    Also should be adjusted the WinProp_Results to WinProp_Results_Plane.
    Best,
    Zeina
    User: "Coco"
    OP
    Updated by Coco
    Dear Zeina,
    Thanks for the advise. However, there's still problem regarding the defination of the prediction plane.
    I defined them like this but unfortunately they're not working.
    Thank you so much, again.
    Coco
