How to use Type of prediction planes in WinProp API indoor
Dear,
I want to predict a plane I defined in database. I searched the pdf of the API and had these values.
However, I failed to find the corresponding variable for it. (xxxxxx = 0?) Meanwhile, I think in the indoor examples, in WinProp_prediction function, the area stored in WinPropArea is used, should it be replaced by WinProp_ResultPlaneList or what?
Would appreciate it if there's an example? or like names of examples in the pdf…
Thank you in advance,
Coco
1 - 1 of
11
Hi @Coco ,
You will need to :
1- Change the Structure WinProp_Area to WinProp_AreaPlane
2- Pass it on to the WinProp_Predict_Planes function instead of WinProp_Predict
Also should be adjusted the WinProp_Results to WinProp_Results_Plane.
Best,
Zeina
Dear Zeina,
Thanks for the advise. However, there's still problem regarding the defination of the prediction plane.
I defined them like this but unfortunately they're not working.
Thank you so much, again.
Coco
