🎉Community Raffle - Win $25
Join and Win
How to set radiation properties in EDEM altair
User: "Seed710"
Altair Community Member
I need to set emissivity for particle and wall of the geometry.
I can't find the option for this input.
1 - 1 of 11
    Hi,
    We don't currently have a particle radiation model in EDEM. There are models for particle-particle and equipment-particle and particle-fluid conduction heat transfer but no radiation heat transfer. If using CFD you may be able to include radiation heat transfer from the geometry but we don't have a particle model.
    It maybe possible in the API but it is likely to be quite a complex implementation
    Regards
    Stephen
