Altair RISE
Nominate Yourself Now!
why is there a difference between windows and linux
User: "satri"
Altair Community Member
Hello
I am trying to deposit a chain of particles i give the chain a downward velocity of 20m/s in windows and linux with a time step of 2.5e-10 the chain deposits in windows without breaking in windows (only difference between the two is windows uses bondingV2 and linux uses bond3_5 api) why does the chains break in linux?
1 - 4 of 41
    Hi, this is likely due to the difference in physics models used. If you use the same on both computers do you get the same result?
    Regards
    Stephen
    Hi Satri,
    If the files are not confidential you can share the files with us for testing.
    If the files are confidential, is it possible to create a generic model similar to that for testing.
    Also, can you please confirm the EDEM version used in Windows and Linux and also is it custom model does you see the difference in model or EDEM standard in-built physics model?
    Thanks,
    Prasad A
    User: "satri"
    OP
    I can share a generic model, but I don't want to put it in this forum. but I can email you. (this is my email satri@ncsu.edu) please let me know if you can send me a email to this i will share a model with you on email i am using edem 2025.0 i am using particle replacement api and snooker factory api
    User: "satri"
    OP
    Stephen, it does not work even if I use bondingV2 and give high velocity in Linux, the chains break. I can't do Bond35 in Windows as it takes an extremely long time.
    Please tell me why this difference occurs
