🎉Community Raffle - Win $25
Join and Win
What is hybrid message passing?
User: "Angel_Ggonzalez"
Altair Community Member
Good day to all,
Someone could tell me please what is Hybrid message passing of the Hypermesh CFD solver and in what cases should I use it? Also if it could help to reduce computational running times.
Thanks in advance.
1 - 1 of 11
    User: "acupro"
    Altair Employee
    Let's say you have a compute node / machine with 20 physical cores - and you specify to run with 20 processors/cores.
    By default AcuSolve will query the machine and determine it has 20 cores - and set 'number of threads' = 20. This would be pure openmp - where it's a single process with 20 threads.
    Pure mpi would be where you specify 'number of threads' = 1. There you would have 20 processes, with 1 thread each.
    Hybrid would be a mix. So let's say you specify 'number of threads' = 5. There you would have 4 mpi processes, with 5 threads each using openmp (to get to the same total of 20 cores used).
    It's explained a little on the following page - if you look for num_threads
    https://help.altair.com/hwcfdsolvers/acusolve/topics/acusolve/solver_programs_acurun.htm
