I need to perform ship-related RCS simulations, but the ship models included with FEKO have very few
Description: [Kindly add description here]
Product/Topic Name : [Kindly include he product name, version if applicable here. Also, Don't forget to tag with the product/topic related to your question. ]
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
Hi @bncc_1634102064 ,
I could try meshing a model of your choice with SimLab or HyperMesh, if it is possible in a relatively short time. If you have a model, you are welcome to attach it here so that I can take a look at it.
Of course, it would be important to know the desired frequency.
Please also bear in mind that large and complex (= detailed) CAD data is very time-consuming to simulate. So you will probably need a lot of memory and computing time.
Best regards,
Torben
Models with more detail often have some form of copyright. You could look for a ship model on grabcad.com. Hover the cursor over Community, then select Library.
Sign in or create an account. It is free of charge and they don't send you spam e-mails.
Then, enter a search term and click the magnifying-glass symbol:
You will get a few dozen results. Look for an interesting-enough ship that can be downloaded in a format that Feko can import, e.g., STEP, Parasolid, ACIS. I don't think Feko can import Solidworks.
Warning: many models on GrabCAD need significant repair before you get a good mesh. Download several and see what works best.
