1 - 3 of
31
Hi,
It's not really a centrifugal loading because it doesn't depend of the radius but the load on my problem is a load oriented in the direction of the vector er of a cylindrical system. So I created the cylindrical system and I created my RFORCE but I don't know how to select the node G. Which as to be in the center of the shaft.
Thanks
Hi,
If it is centrifugal loading, you can create RFORCE and fill the required parameters like G for grid id, CID, A for rotational velocity, RACC for rotational acceleration etc.
Refer the below link for more info.
https://help.altair.com/hwsolvers/os/topics/solvers/os/rforce_bulk_r.htm?zoom_highlight=rforce
How to Use RFORCE Load with Hypermesh OptiStruct — Altair Community
Thanks…
