🎉Community Raffle - Win $25
Join and Win
Curve for motion is not working
User: "Shiva Kumar"
Altair Community Member
ERROR: Processing data for Spline [id=301001].
I have a spline which i have given as an input to a motion. But the above error is showing up. Please help, i have attached the mdl file
1 - 2 of 21
    User: "Vishvam"
    Altair Employee
    Accepted Answer
    Hello @Shiva Kumar
    The curve values needs to be in increasing order, and the same error is seen in the .log file
    See attached images. You can make the values increasing and try, and that should resolve the issue.
    Your curve values:
    Hope this helps!
    User: "Shiva Kumar"
    OP
    Thank you Sir, ill resolve it
