🎉Community Raffle - Win $25
Join and Win
Exporting grid bin group query to csv or text Postprocessing
satriUser: "satri"
Altair Community Member
Hello
Is there a way to export the query table produced in when grid bin group is created?
See the image bellow
I can copy the table bellow into excel but it needs lot of data cleaning
and why does it put it in two rows is there any alternative.
Is there a way tp export the data from query to csv file where everything is in one line?
1 - 9 of 91
    satriUser: "satri"
    OP
    Updated by satri
    Even if i save the file as a csv file it puts the first coordinate in the second line
    I want everything in one line. is there any way to do that?
    Hi Satri,
    It looks like the first line is a description of what is exported, you can omit header info or omit text in the Export Results Data > General dialog box
    satriUser: "satri"
    OP
    No i am not exporting with that option. i am creating bins that i am displaying on the console similar to the voidage calculations shown here
    (https://www.youtube.com/watch?v=YzOSjA0sPz4)
    but the output is in the console and i want to export it into a file.
    I do not know how to export results from grid bin group query to a text file
    In the Analyst > File > Export Results Data and under Queries you can select the grid bin group under Selection as shown.
    This is the queries tab, under the General tab you can set the data shown in the previous screenshot.
    Regards
    Stephen
    satriUser: "satri"
    OP
    ohh i did not see that new option.
    Thank you for suggesting that.
    satriUser: "satri"
    OP
    Hi I am trying to export a value of mass using this
    I am getting the mass but i want the mass saperated in grid form in the data.
    Is there a way to show that?
    satriUser: "satri"
    OP
    Even if i give the option apply to subsections i get this data
    How do i know what subsection is what. is there a way to put the centroid of the subsection along with this?
    The bins start in the -X, -Y, -Z corner and step in Z first, then Y then X. You can use Analyst > Selections > Display Options > Edit > Highlight sub-sections to visualise which one is which.
    The 'apply to subsections' should export the data per bin.
    Regards
    Stephen
    satriUser: "satri"
    OP
    got it thank you. Please tell me this. i have been considering to use the python postprocessing tool is there any post-processing tool to export data in python deck to computer solid volume fraction.
