Inspire non-deserialized results and PhysicsAI
Dear community,
I have fully parametrized a pressure vessel using Inspire to generate lots of data through DesignExplorer to create a PhysicsAI project.
Although, the DoE result files are in a deserialized format, such that each run of the DoE is broken into 6 different "optiResHvtransOut.h3d" files.
Is it okay to feed these into pAI?
If not, how can I keep a single .h3d for each run of a DoE?
Thank you.
