🎉Community Raffle - Win $25
Join and Win
Can altair simlab cancle element jacobian check during calculation?
User: "QinHe_321"
Altair Community Member
While using explict solver, to avoid error 7053
1 - 1 of 11
    User: "yuhaohe"
    Altair Employee
    There are two explicit solvers in the backend of SimLab. If you are using OptiStruct as the solver, you can disable element quality check in Settings→Solver Settings→CHECKEL→No. However, the solver will still stop running if the element quality is too bad, such as negative jacobian.
