Inspire PolyFoam Batch Mode
User: "Shinwoo"
Altair Community Member
Hello,
I was wondering if it's possible to run PolyFoam in batch mode. I know that Inspire can be run this way.
Thanks in advance.
Shinwoo
1 - 4 of 41
    @MilanRaval, kindly provide the suggestions for executing Inspire PolyFoam in a batch mode.
    Many thanks.
    Kind Regards
    Garima Singh
    User: "MilanRaval"
    Altair Employee
    Hello @Shinwoo,
    If you are referring to export a batch folder and then running from the pre-created input folder with setup, mesh and configuration, this is how you can access the feature.
    User: "MilanRaval"
    Altair Employee
    If you are trying to run on cluster, that feature is not yet available in PolyFoam. Potentially coming to PolyFoam in upcoming release. You can also configure your multiple runs based on parallel or sequential computing on local machine.
    User: "Shinwoo"
    OP
    Thank you for your support!!!
