1 - 3 of
31
Hello Leon,
Unfortunately is not possible within Flux: you should export the local quantities versus time and then use an external script to use the iGSE method and compute the derivative.
Alternatively, iron losses can be calculated using the "automatic" modified Bertotti method available in Flux.
Best regards,
Letizia
Hello Leon,
Thanks for writing.
It is possible to calculate the derivative of a curve within Flux, you can find more information here:
https://help.altair.com/flux/Flux/Help/english/UserGuide/English/topics/Courbe2DDerivee.htm
Best regards,
Letizia
