🎉Community Raffle - Win $25
Join and Win
Ticket for issue with Hypermesh Batch Processing
User: "William Kuo_21386"
Altair Community Member
Hi Altair Community,
I have been having issues having Altair batch processing work in python with my for Hypermesh 2025.
Is there a way to get a ticket? I've reviewed all the "batch" related posts and I haven't had a successful solution yet.
Image 1: My check.py script only prints out "hello"
Image 2: No output when I use "-b". I ran command prompt in administrative mode. Even if I were to process something, that hypermesh instance won't pop up.
Image 3: When I run it without "-b", it opens Hypermesh 2025 GUI and outputs "hello" in python console.
Any help? I've made a previous post and comments over the past month but I have not found a solution yet.
Sincerely, William
1 - 5 of 51
    User: "GTT Adam"
    Altair Employee
    Hi @William Kuo_21386,
    Support Tickets can be created at the following link:
    Cases - Altair Support
    What are you trying to have printed to the Python Window?
    Hope this helps!
    Adam Reid
    OP
    Hi @GTT Adam,
    It says I do not have the ability to create a case. I assume this is because the hypermesh software I am using is not registered under my account.
    As a test, I am simply printing "hello", as shown in the screenshot. This is correctly outputted on the python console in hypermesh but not so in the command prompt when I use "-b".
    Sincerely, William
    OP
    Hi @GTT Adam,
    Any chance for further support?
    Sincerely, William
    User: "GTT Adam"
    Altair Employee
    If you are unable to use the account that is registered for this product, please contact your Account Manager to see if you have the ability to create support cases.
    Hope this helps!
    Adam Reid
    OP
    Hi @GTT Adam,
    My license is part of a network wide license for an institution. I do nothave the ability to contact my account manager.
    Sincerely, William
