Ticket for issue with Hypermesh Batch Processing
Hi Altair Community,
I have been having issues having Altair batch processing work in python with my for Hypermesh 2025.
Is there a way to get a ticket? I've reviewed all the "batch" related posts and I haven't had a successful solution yet.
Image 1: My check.py script only prints out "hello"
Image 2: No output when I use "-b". I ran command prompt in administrative mode. Even if I were to process something, that hypermesh instance won't pop up.
Image 3: When I run it without "-b", it opens Hypermesh 2025 GUI and outputs "hello" in python console.
Any help? I've made a previous post and comments over the past month but I have not found a solution yet.
Sincerely, William
Hi @GTT Adam,
It says I do not have the ability to create a case. I assume this is because the hypermesh software I am using is not registered under my account.
As a test, I am simply printing "hello", as shown in the screenshot. This is correctly outputted on the python console in hypermesh but not so in the command prompt when I use "-b".
Sincerely, William
If you are unable to use the account that is registered for this product, please contact your Account Manager to see if you have the ability to create support cases.
Hope this helps!
Adam Reid
Hi @GTT Adam,
My license is part of a network wide license for an institution. I do nothave the ability to contact my account manager.
Sincerely, William
Hi @William Kuo_21386,
Support Tickets can be created at the following link:
Cases - Altair Support
What are you trying to have printed to the Python Window?
Hope this helps!
Adam Reid
