Error while running motionview exported model in Adams
Description: [Porting Motionsolve subroutines to Adams]
Product/Topic Name : Motionview
Hi,
I have a vehicle model built in motionview that I would like to solve with Adams solver. I had exported out the acf, adm files and was able to submit the job to adams.
However, there are some outputs which require subroutines which are specific for Motionsolve. I get the following error
"Encountered error "The user library "msautoutils" could not be located"
I copied the msautoutils.dll to the same directory as the simulation input files after which this error disappeared. But i got a new error
"ERROR: Unable to establish AccessFunction connection, please set NUSOL_DLL_DIR"
I added a new environment variable named NUSOL_DLL_DIR along with the equivalent path
After this the simulation starts but exits without any further message.
Also, in the adm file, i see that msautoutils subroutine is being called instead of equivalent relevant adams subroutine. I would like to understand why motionsolve subroutine is being called while exporting the model to Adams.
I would like to know how to port the Altair subroutines to Adams correctly. Could you guide me with the process?
Regards
Karthikeyan
