🎉Community Raffle - Win $25
Join and Win
Meta Particle Generation
User: "Johnson"
Altair Community Member
Good day,
I hope this email finds you well.
Please, I am trying to generate meta particles for spherocylinders to model a corncob. I decided to overlap meta particles to create bumps on the surface, making it resemble the texture of a cob. However, after ensuring that everything is defined correctly, the meta particle is still not generating. I'm unsure if the issue is due to the significant overlap that might be preventing the generation.
I have attached the simulation file to this message. In the current setup, I have only included the factory because I simplified the simulation. I plan to add the geometry once the particle is successfully generating.
Please, I will appreciate any assistance on this.
Thank you.
