🎉Community Raffle - Win $25
Join and Win
Missing Global system on the graphic interface
User: "Raoul"
Altair Community Member
Description: [Good evening everyone, I'm student edition altair user, since two weeks I face an incomprehensible problem with my Global system in any new session I tried to start, so it's impossible for me to works, I don't know if someone before me faced too that kind of problem, if yes, how he or she have saved that? Thank you]
Product/Topic Name : [I'm using hwdesktop 2023.1, I have unstalled and installed but nothing had change on the situation. Thank in anticpation for your contribution I will be really thankful to read you.
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
1 - 4 of 41
    Hi,
    Can you check your Appearance setting in "Preference" and confirm that "Show Global Axis" is ON?
    Refer the below image for same.
    Thanks
    Rajashri
    User: "Raoul"
    OP
    Thank you very much Rajashri for your answer. But I think that the problem is more complex, I don't really know what's not going on when I reinstalled it, it work well for some minutes after that the global system and cube disappear and the software close itself alone!.
    User: "Prajval_cu"
    Altair Employee
    Hi
    This issue may be due to an incompatible GPU or outdated drivers. Could you please ensure that you're using a supported GPU? Also, try updating the GPU drivers using a clean and custom installation with the latest version, and then give it another try.
    Regards
    Prajval
    User: "Raoul"
    OP
    Ok Thank you, I will try on that way, and will tell you back later if it's working or not!
