Restart File not created
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm currently working on getting HyperForm simulations to run and have been quite unseccesful seeing as the tutorials seem to be written for an older verison of Hyperform and do not coincide with the updated user interface.  I have been trying to solve the 'simple draw forming' tutorial using incremental RADIOSS and have solved many problems that have arisen, however I cannot seem to figure out this last one.  When I run I get error ID 684 'Error Trapped: Report to listing file' as well as Error ID: 760  'Restart file Attempt2_0000_0001.rst was not created.'   I then decided to switch to Ls-Dyna solver and noticed that when I go to run analysis is requests that I tell it the location of the solver?  I cannot understand what it is looking for as it does not even indicate a specific file type.
I appreciate any support you can provide.
Thanks in advance
1 - 1 of 11
    Altair Employee
    OP
    Hi,
    delete all the files except the two .rad files. In the windows All pograms list you would find the Radioss in the Altair Hyperworks application list. In the Radioss solver manager select the 000.rad file.
    For the Options you need to select -both, -nthread (specify 2 or 4), -noh3d.
    This should get the solver running.
    For LS-Dyna solver you need LS-DYna software and license to use it.
    Hope this helps.
