DSIM UVM Hello World Project giving error
Hello
While elobrating the UVM hello World project I am getting following error on windows machine. I have a feeling it has to do with some eniroment setup where space in the environment setup is not being handled.
The following dynamic $cast cases will always be false
C:\Program Files\Altair\DSim\2025\uvm\1.2\src\base\uvm_callback.svh:521:9 class uvm_pkg::uvm_callbacks#(class uvm_pkg::uvm_phase,class uvm_pkg::uvm_phase_cb) class uvm_pkg::uvm_callbacks#(class uvm_pkg::uvm_phase,class uvm_pkg::uvm_callback) Included from C:\Program Files\Altair\DSim\2025\uvm\1.2\src\base\uvm_base.svh:76:3 Included from C:\Program Files\Altair\DSim\2025\uvm\1.2\src\uvm_pkg.sv:31:3
C:\Program Files\Altair\DSim\2025\uvm\1.2\src\base\uvm_callback.svh:671:12 class uvm_pkg::uvm_phase class uvm_pkg::uvm_report_object Included from C:\Program Files\Altair\DSim\2025\uvm\1.2\src\base\uvm_base.svh:76:3
C:\Program Files\Altair\DSim\2025\uvm\1.2\src\base\uvm_callback.svh:731:10 class uvm_pkg::uvm_component class uvm_pkg::uvm_phase Included from C:\Program Files\Altair\DSim\2025\uvm\1.2\src\base\uvm_base.svh:76:3
C:\Program Files\Altair\DSim\2025\uvm\1.2\src\base\uvm_callback.svh:808:10 class uvm_pkg::uvm_component class uvm_pkg::uvm_phase Included from C:\Program Files\Altair\DSim\2025\uvm\1.2\src\base\uvm_base.svh:76:3
Found 6 unique specialization(s) of 6 design element(s).Optimizing...Building models...PLI/VPI access: (none) Simulation time precision is 1ns. [1/9] module $root: 1670 functions, 3684 basic blocks [2/9] module $pkgs: 1 functions, 2 basic blocks [3/9] CU scope $unit: 1 functions, 2 basic blocks [4/9] module top: 2 functions, 6 basic blocks [5/9] package std: 31 functions, 80 basic blocks [6/9] package uvm_pkg: 5 submodules, 3616 functions, 39621 basic blocks [7/9] package my_pkg: 10 functions, 28 basic blocks [8/9] interface dut_if: 1 functions, 2 basic blocks [9/9] module dut: 1 functions, 2 basic blocksLinking image.so...ld: cannot find C:\Program: No such file or directoryld: cannot find Files\Altair\DSim\2025\uvm\1.2\src\dpi\libuvm_dpi.so: No such file or directoryds_ld Altair DSim version: 2025.0.0000 (b:S #c:32 h:e6a01125e5 os:msys2_)
Altair DSim 2025.0.1 is now available in the AltairOne Marketplace. This release should fix the issue.
This issue is a known limitation for Windows machines and will be fixed in the next release of DSim.
Limitation: DSim cannot find UVM library on Windows machines
