🎉Community Raffle - Win $25
Join and Win
Find Hole and Create Rigid, In this script, How to add Outer Periphery nodes of the Hole also to Create a Rigid, Currently it only take inner Nodes of the Hole Based on the element edges, but we need to add outer periphery of node so that it create r
proc spider {} {
    if { [ hm_marklength nodes 1 ] != 1 } {
        hm_errormessage "More than one node passed to spider procedure"
        return {}
    set nodeId [ hm_getmark nodes 1 ]
    hm_blockmessages 1
    *entityhighlighting 0
    *clearmark comps 2
    *findmark nodes 1 1 1 components 0 2
    *findedges components 2 0
    *createmark elems 1 "by comps" {^edges}
    set edgeElems [ hm_getmark elems 1 ]
    foreach eId $edgeElems {
        set plotelem2Nodes($eId) [ hm_nodelist $eId ]
        foreach nId $plotelem2Nodes($eId) {
            lappend node2Plotelems($nId) $eId
    *deleteedges
    hm_blockmessages 0
    *entityhighlighting 1
    if { ! [ info exists node2Plotelems($nodeId) ] } {
        # selected node is not on an edge
        hm_errormessage "Please select a node on an edge."
        return {}
    set endNode $nodeId
    set nodelist {}
    set nextNode $nodeId
    set nextElem [ lindex $node2Plotelems($nodeId) 0 ]
    set counter 0
    lappend nodelist $nextNode
    while { $counter < 10000 } {
        set prevNode $nextNode
        set prevElem $nextElem
        set nextNode [ lremove $plotelem2Nodes($prevElem) $prevNode ]
        if { $nextNode == $endNode } { break }
        set nextElem [ lremove $node2Plotelems($nextNode) $prevElem ]
        incr counter
    if { $counter > 9999 } { set nodelist {} }
    # create and return the element
    set elemId {}
    if { [ llength $nodelist ] } {
        eval *createmark nodes 2 $nodelist
        *rigidlinkinodecalandcreate 2 0 0 123456
        set elemId [ hm_entitymaxid elems ]
    return $elemId
Here it takes only inner Periphery of the Hole, Can you Help me to Update that, So that it can take outer node of washer as well
1 - 2 of 21
