proc spider {} {
if { [ hm_marklength nodes 1 ] != 1 } {
hm_errormessage "More than one node passed to spider procedure"
return {}
set nodeId [ hm_getmark nodes 1 ]
hm_blockmessages 1
*entityhighlighting 0
*clearmark comps 2
*findmark nodes 1 1 1 components 0 2
*findedges components 2 0
*createmark elems 1 "by comps" {^edges}
set edgeElems [ hm_getmark elems 1 ]
foreach eId $edgeElems {
set plotelem2Nodes($eId) [ hm_nodelist $eId ]
foreach nId $plotelem2Nodes($eId) {
lappend node2Plotelems($nId) $eId
*deleteedges
hm_blockmessages 0
*entityhighlighting 1
if { ! [ info exists node2Plotelems($nodeId) ] } {
# selected node is not on an edge
hm_errormessage "Please select a node on an edge."
return {}
set endNode $nodeId
set nodelist {}
set nextNode $nodeId
set nextElem [ lindex $node2Plotelems($nodeId) 0 ]
set counter 0
lappend nodelist $nextNode
while { $counter < 10000 } {
set prevNode $nextNode
set prevElem $nextElem
set nextNode [ lremove $plotelem2Nodes($prevElem) $prevNode ]
if { $nextNode == $endNode } { break }
set nextElem [ lremove $node2Plotelems($nextNode) $prevElem ]
incr counter
if { $counter > 9999 } { set nodelist {} }
# create and return the element
set elemId {}
if { [ llength $nodelist ] } {
eval *createmark nodes 2 $nodelist
*rigidlinkinodecalandcreate 2 0 0 123456
set elemId [ hm_entitymaxid elems ]
return $elemId
Here it takes only inner Periphery of the Hole, Can you Help me to Update that, So that it can take outer node of washer as well
