🎉Community Raffle - Win $25
Join and Win
Custom Guidebar - Apply or Proceed with middle mouse
User: "SLadisch"
Altair Community Member
Description: How to use the middle mouse button to apply or proceed in a custom guidebar
Product/Topic Name : HyperMesh 2024.1 - Custom Extension
I've sucessfuly added a custom guidebar to my extension. The guidebar has an apply (or proceed) button which does the job and clears the selection afterwards. And it has an "ok" button which does the job and closes the script.
Now the Question is: Is it possible to listen to the middel mouse button an fire the proceed-funktion. This is the way the most built-in-guidebars work.
1 - 2 of 21
    User: "SLadisch"
    OP
    # This is a tcl script that interfaces w/ HM. #
    itcl::class ::HoermannScriptingHM::RodMeshCtx {
    inherit ::hm::context::HMScriptableBase
    constructor {args} {}
    public method proceed {args};
    public method ok {args};
    itcl::body ::HoermannScriptingHM::RodMeshCtx::proceed {args} {
    set nodeIdList [ctx::selection ids "NodeSel"]
    ::HoermannScriptingHM::RodMesh $nodeIdList
    ctx::selection clear "NodeSel"
    itcl::body ::HoermannScriptingHM::RodMeshCtx::ok {} {
    proceed
    ctx exit
    proc ::HoermannScriptingHM::RodMesh { nodeIdList } {
    eval *createlist nodes 1 $nodeIdList
    set node_list [ hm_getlist nodes 1 ]
    #set node_list [ctx::selection ids NodeSel]
    puts $nodeIdList
    puts $node_list
    if { ! [ Null node_list ] } {
    *createelements1d nodes list=1 useelemdensity=1 elemdensity=1 engineeringconfig=ROD propcardimage=PROD linecomp=0 useshell=0 biasintensity=0 biasstyle=0
    #::CustomerName::Main
    ctx::manager register hm RodMeshCtx "::HoermannScriptingHM::RodMeshCtx"
    User: "SLadisch"
    OP
    Any idea? Anyone?
