Get contact area in cuda
satri
satri Altair Community Member
edited March 20 in Community Q&A
Hello
I have two spheroCyl particles or two sphere particles. I am running them through Cuda. I wanted to compute the contact area of them when I define a variable real coA = contact.getContactNormalArea(), I always get the value zero even though the particles are inside the contact radius. Why is this so, and how can I fix this?
I get zero even if I print 30 significant digits after the decimal point.
Answers
  • satri
    if i put that inside this i get 0 if i print outside
    if (contact.getNormalPhysicalOverlap() <= REAL_CONST(0.0))
    return;
    I do not get 0. Is there any in built variable that keeps track of this? I am asking this because for sphere i can write based on geometry. but i am not sure what to do for spherocyl.
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi Satri,
    Contact overlap is for Polyhedral only, the Spheres and Sphero-Cylinders give overlap as a normal distance not area.
    Regards
    Stephen
Welcome!
Welcome!
