1 - 8 of
81
You cannot measure distance to a comp, because comp is a combination of nodes, elems, surfs, lines, points... you have to indicate which primary entity is, example
hm_measureshortestdistance nodes .... surfs ....
in that, surfs are pre-selected by *createmark surfs 1 'by comp' $the_comp_you_want_to_measure
hi,
@George P Johnson that command is used only for node-node or point-point. But thanks anyway\
@tinh well, my model contains only temp node and comp with element, there is no such thing like surface or line. That why I have to come here, looking for a solution.
Hi Toan,
Did you try with hm_getdistance
The format is hm_getdistance entity_type id1 id2 syst_id
