Topography optimisation
Punith
Punith Altair Community Member
edited October 2020 in Community Q&A
Hi,
I want to run a topography optimization of a sheet metal component, but I would like to restrict the shape change with barrier mesh inside and outside due to the adjacent components. How can I do this?. Can someone help me with this concern?. I know that barrier mesh option is available in free shape optimization but I really want to make use of only Topography optimization as it is a sheet metal component.
Thanks and regards,
Punith
Answers
  • Simon Križnik
    Simon Križnik Altair Community Member
    edited January 2020
    Hi,
    in topography optimization formulation make sure to define draw height (to a lesser extent minimum bead width and draw angle) so as not to violate package space of adjacent components.
    Since version 2019 a new GRID-based free-shape optimization with more flexible shape changes for shells and solids, enabling the nodes to move normal to the surface is available. This method would probably also allow barrier mesh option.
    d58ccd2be87581ba14dd1cc703a2767e76784602.jpg?image_play_button_size=2x&image_crop_resized=960x614&image_play_button=1&image_play_button_color=54bbffe0
    Altair OptiStruct Grid Based Free Shape Optimization
  • Punith
    edited January 2020
    Hi,
    good to know. Thank you so much Simon. Let me try it.
    Regards,
    Punith
Welcome!
Welcome!
