Modelling of the ground as a PEC plane.
Student_21133
Student_21133 Altair Community Member
edited March 16 in Community Q&A
Hello everyone,
As you know, Feko allows to consider a perfect ground plane as a PEC :
cf. https://help.altair.com/feko/topics/feko/getting_started_guide/GS5_emc_coupling/emc_coupling_infinite_plane_feko_t-example5.htm
Would it be possible to know which electromagnetic technique is used to model this ground plane ?
Thanks in advance.
Best Answer
  • Zeina
    Zeina
    Altair Employee
    Answer ✓
    Hi @Student_21133,
    Adding a PEC ground plane allows the computation of the reflected field using the exact reflection coefficients; it is then added to the total field.
    Please check this section of the guide where more details about Infinite planes can be found.
    Best Regards,
    Zeina
Answers
  • Zeina
    Zeina
    Altair Employee
    Answer ✓
    Hi @Student_21133,
    Best Regards,
    Zeina
  • Student_21133
    Hi Zeina,
    Thanks for your reply.
    So in the case of using the method of moments for an infinite PEC plane as the ground, does Feko just replace the free-space Green's dyad with the Green's dyad for a perfect ground, which represents a reflection ?
    Thanks if you have any information on this.
    Best regards, and have a nice day.
Welcome!
Welcome!
